This may be a stupid question but! Is it ok to change my oil after I warm my bike up of coarse but the new oil has been sitting in the garage and is cold from this damn winter? I didn't know if the cold oil hot engine combo would be ok?
You should alway warm the bike up before an oil change. Warm oil will drain better. As far as adding the new cold oil, it will be fine. By the time you replace the oil filter and drain plug, the case will have cooled down and cooler oil won't hurt a thing.
So how about taking the cold oil into the house for an hour to warm it up first?
I set my new oil bottles in the sun to warm a bit, makes them drain faster and more thoroughly. I only put 3 qts in at an oil and filter change, takes it half way between marks on dipstick.
