RUB 2 1/2
I'm 5'4" just bought a flht the dealer lowereed the front 1 " and 12" shocks on the rear with a bracket, i dont notice alot of differance still on tip toes. does the RUB 2ADJ KIT` work or am i spending more $ $$$ . for right now ill deal with the ride, i need some ride time with some security at stops and backing up etc. the seat is a streetglide also. bob
With the RUB that you are looking at, you will have bottoming out issues and to avoid that you will have to increase the air pressure in your shocks. Not a very good trade off. You have several options. First and foremost I would recommend a good pair of logger style boots such as Chippewa. They have a higher heel and thicker sole that give you added height, not to mention great road grip. Another option is getting a custom seat or having your seat modified. I would advise against the HD Reach seat. IMO it is a very uncomfortable seat.
I'm 5'6" and had my 06 Ultralowered 1" front and back. This worked for me. I had a 95 Ultra which i tried lowering 2 times. the move to 2.5" lower rear didn't work; it dragged to much. The95 started about an 1" higher than the 06. A pair of thick soled boots helps, the HD brand work pretty good, but are so heavy when walking around.
Check the air pressure in your forks and shocks. a lot of times it's set higher than you need. iweight about 180 and can do fine with about 5 psi in the shocks, and no suspension problems.
BOL.
BOL.
You might want to check out the Mean City Cycles ad on this forum. He can lower your seat and actually make it more comfortable. Lot's of people are having 2" removed and find it more comfortable. Great price too.
ORIGINAL: boe1971200
Oh man I wouldnt start talking about RUBs on this board.
I'm 5'6" and the mod by Allen at Mean City Cycles made a lot of difference, plus he added memory foam which gives me the lowest, most comfortable seat available.
Call Allen and tell him what you want done -- he can do it, and it won't cost you a fortune. Very reasonable.
What was said about the boots will help too, so do both.
Good luck.
Jim
Good luck.
Jim
H-D has seats available for the vertically challenged...**** on it, for short people... not sure how comfy. They are called the "Reach" seats and start on page 407 of the catalog.
Part # 52544-05A fits '97 and later FLHT.
Talked to allen by email his shop is right down the road from me! I thinks Im going there first! P.S. I wore my foerst service FF boots a bit heavy but they did help. Now If I could get used to the electra glide compared to the sportser ......big differance God I love riding it, like a cadalic smoooooth. Bob
