Loctite Motorcycle Application Guide
I seem to get confused in regards to the various Loctite products. When someone talks about the medium strength (blue), do they mean: 242, 243, 248, 249, etc
or high strength (red), do they mean: 262, 268, 271, 272, 277, etc
These guides provided me with some good information
http://www.loctite.ph/php/content_da...tion_Guide.pdf
Loctite Automotive Aftermarket Adhesive and Sealants Guide
https://www.nytechsupply.com/downloa...inecatalog.pdf
I never lose sleep over the numbers. Although I have been using Prematex Threadlockers for a while now and they only have the colors. For the most part purple for really small screws, use this only on RC airplanes and cars. Blue for small bolts, red for big bolts and green is for wicking. There is a few specific choices for red but there is only 1 choice for blue and purple.
At home I have found no use for anything other than blue except for purple for some hobbies. Even then I used to use blue and will probably go back to that when the purple runs out.
Loctite is great stuff and necessary for a number of applications but the link lists tread sealant for oil, primary, and transmission drain plugs. Thread sealant is for tapered threads, Harley plugs have straight threads and rely on an O ring to seal the fluids. nothing else needed.
Right or wrong I dunno, I don't use any sealant on my drain plugs either, I know it came with thread sealant but I also rely on a new o ring each time with no issues.
