Sounds like a tractor...(?)
Old Jul 13, 2015 | 11:04 PM
tphillips's Avatar
tphillips
Default Sounds like a tractor...(?)
Okay, I know this is one of those "How long is a rope?" questions, but I will give it a try:
I have a 2005 Ultra 88" with 66k miles on it. Stage 1 with SERT. Change the oil regularly every 5k and only use synthetics in all 3 holes. Lately I have registered a low gnarly sound from the front of the engine at idle that sounds like a tractor. It is louder than it has been and literally sounds like I have a John Deere down there.
Any thoughts? Fire away... And thanks in advance.
Old Jul 13, 2015 | 11:24 PM
sn95bullitt's Avatar
sn95bullitt
Probably your cam chain tensioners.
Old Jul 14, 2015 | 07:46 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
What do you mean by "sounds like a tractor"? A little elaboration for clarification please.
Old Jul 14, 2015 | 08:16 AM
KCFLHRC's Avatar
KCFLHRC
Well, my John Deere tractor has a 3 cylinder Yanmar Diesel in it, and if my bike sounded like that I would be very concerned.
Old Jul 14, 2015 | 08:53 AM
tphillips's Avatar
tphillips
Hmmm... Concerned. Thanks.
With regard to "elaboration," I can't think of more detailed description other than it is only audible at idle, sounds gnarly and like diesel tractor idle, but no change in performance at any speed.
Tensioners were changed at 40k.
Thanks all for feedback.
Old Jul 14, 2015 | 10:48 AM
gipper's Avatar
gipper
I would seriously consider pulling the compensater and taking a look at that. It's easy to get to, and when they wear out they can make some noise, for sure.
Old Jul 14, 2015 | 11:26 AM
Ride my Seesaw's Avatar
Ride my Seesaw
Does it sound anything like this?
Old Jul 14, 2015 | 10:54 PM
tphillips's Avatar
tphillips
Originally Posted by Ride my Seesaw
Hahahaa! Yeah, 'cept without the pickin'!
Old Jul 14, 2015 | 11:25 PM
wscott's Avatar
wscott
With 66k miles 1st thing i'd check would be Compensator & prim chain tensioner & if not either of those are shot then maybe cam chain tensioners could be shot.
But it depends on what side of motor the noise is coming from ,the comp & prim chain tensioner are on left side of the motor and cam chain tensioners are on right side.
Scott
Old Jul 14, 2015 | 11:39 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
well, without hearing the noise -- 1. Intake gasket from or 2. Exhaust gasket
