seems my light quit working,, any sugestions ?? burnt bulb ,, sender ,, looked in the manual cant find anything . i know the warning is on the speedo but does not come on,, even with the ignition ,,, any help??
You've been on the forums for a bit and life in gen. Diagnostic Trouble Codes.
ok i call it trouble codes ,, but thanks ,, just went to pull codes ,, all lights light up including the low fuel light,, in all positions i got the reading none, so what else could it be ??
As I recall the LF light takes information from the gauge so if the gauge works I'd say its either the light itself of the issue is between the gauge and light.
