Clutch Pack Cover? and other mundane q's
I'm contemplating purchasing/installing a compensavor as I have to replace my compensator.
Why the foxtrot wouldn't Harley engineers come up with a modified solution from the get go?
It is my understanding what used to be considered the SE Compensator is now simply what you get when order a compensator?
Please look at fig1 and fig2 on this photo... what is that cover or shield over the clutch pack in fig1?
I would agree, that is a Bandit Sportsman.
Compensaver is a good product. I have one but only have a couple thousand miles on it. Have a caliper there and measure your compensator & stack height. Also a new bolt. The HD compensator kit will have one. You will need a T70 socket and big old long torque wrench. Hardest part of the job is relieving the webs on the inner primary for the Compensaver tray. The HD tray had been cast in on my primary on mine. A running change by the MOCO; Change the primarys for a better comp, but use up all the inferior ones we have in stock.
I had a Rivera 31 tooth sprocket delivered to day so I'll be going back in mine. Dropping one tooth on the primary socket will help low end grunt & the casting is smoother too.
Yeah, I think you are correct on that. The Rivera is one tooth less than stock and you get a shoe add on to take up difference.
I really like the Compensaver, so far. I have a 09 Dyna that is more of a hot rod and it will get a new compensator this winter. I'm going Baker on that one. New Rotor is right around $200. Would love to see Baker offer theirs w/ one less tooth. Would reaally like to see someone other than HD make a rotor.
I have 3 Harleys (79, 09, 13) and am so DISGUSTED with some of the chit QC / engineering the MO CO does I avoid their parts if at all possible. Thus Baker & I hope there is an aftermarket option for the rotor.
....Have a caliper there and measure your compensator & stack height. Also a new bolt. The HD compensator kit will have one. You will need a T70 socket and big old long torque wrench. Hardest part of the job is relieving the webs on the inner primary for the Compensaver tray. The HD tray had been cast in on my primary on mine....
I will get a caliper and measure compensator & stack height but must admit I'm having a hard time conceptualizing the task.
