Shorty antenna
Old Sep 30, 2015 | 06:00 PM
digdug's Avatar
digdug
Default Shorty antenna
Does anyone know if someone makes a very short antenna for a 2015 SGS? I put a tour pack on and need one that won't hit the bottom of it. I believe the HD "shorty" is like 19 in. which is still too long.
Old Sep 30, 2015 | 06:05 PM
mkguitar's Avatar
mkguitar
pepboys rubber stubby, $15
it fits under the tourpak, just push it out of the way
Mike
Old Sep 30, 2015 | 06:06 PM
ybnorml's Avatar
ybnorml
Any chance you can relocate where it's mounted ??
Old Sep 30, 2015 | 06:21 PM
JMC22's Avatar
JMC22
I cut my stock antenna to the size I wanted with a dremmel then popped the rubber cap off the old end and attached to the cut end....
Old Sep 30, 2015 | 06:57 PM
SGMongoose's Avatar
SGMongoose
you should look into the J&M internal antenna. a little pricier but you won't have to deal with an antenna at all
Old Sep 30, 2015 | 07:56 PM
Fatsacz's Avatar
Fatsacz
Hidden antenna, that's the route I took. Works great, and don't forget to purchase the facia plug... Wasn't included with Harley's kit.... Go figure lol
Old Sep 30, 2015 | 09:13 PM
Scott14SG's Avatar
Scott14SG
There is a relocation bracket kit if you want to pay 70 bucks, it moves it back far enough where the shorty won't hit the tour-pak.
Old Sep 30, 2015 | 09:22 PM
Jamyers13183's Avatar
Jamyers13183
Just be aware, nothing sounds good as the stock whip, but everything shorter does look better. I still ended up with a shorty from hd. No regrets!
Old Sep 30, 2015 | 09:23 PM
TcHunter's Avatar
TcHunter
I purchased a 6" off eBay works great, plenty of clearance between the mount and the tour pack.
Old Nov 21, 2015 | 10:40 AM
tejasrider's Avatar
tejasrider
I did the same after I saw your post, works just fine.
