CVO muffler question?
Old Oct 10, 2015 | 05:34 PM
rjm-1's Avatar
rjm-1
Originally Posted by Sam D.
What Brand Tuner are you using now?
He did a dyno tune using Direct Link Delphi. All I got was a USB stick.
Old Oct 10, 2015 | 05:41 PM
rjm-1's Avatar
rjm-1
Originally Posted by Just Me
I cant for the life of me see why anyone would spend the bucks for a dyno tune on a stage one?
You could of simple bought a Dyno-jet tuner from Fuel Moto for way less than what you have wasted into dyon tunes and been happy as a bug in a rug.
Oh you are so right! I already had a FuelPak on it and should have just contacted V&H for a revision. The only reason I went with the dyno tune is that I'm a newbie when it comes to Harley tuning and my buddy said he did such a great job on his Superglide. Initially I said no to the dyno but the decel popping got the best of me and made the decision to go for the dyno tune "KNOWING" he would get rid of the decel popping! Live and learn!
Old Oct 12, 2015 | 09:10 AM
Rush Racing Products's Avatar
If you get a decel pop, it's a tuning issue. Only other thing could be an intake or exhaust leak, that is causing a tuning issue. Almost every time I've exhausted every option with a customer, it ended up being an intake leak causing the issues.
There are limits on what baffles to use for different setups. The 3" baffles and SB1 are only for use with cat equipped headers. They are not for use with open head pipes. All other sizes should have no tuning issues. The 2.50" can be difficult to tune with open headers but it's definitely possible, sometimes requires a dyno tune instead of just a map. All other baffles sizes should be easily tunable. If you don't have engine work done, the downloadable maps work great. CVO models almost always require dyno tuning. Please let me know if I can answer any specific questions.
-Ryan
Old Oct 12, 2015 | 09:31 AM
billnourse's Avatar
billnourse
I have a friend that is wanting to do this upgrade and I started a new thread about this before I saw this one. Questions: How loud and what kind of sound compared to Rush, Rinehart, Vance and Hines, etc. with 1 3/4, 2, etc. He is wanting a bit more sound, but not offensive, and some deep rumble. Will these inserts do the job and what would be the best size. He had Freedom Performance on his 2014 Limited and liked them.
Bill
Old Oct 13, 2015 | 05:40 PM
rjm-1's Avatar
rjm-1
-Ryan
Hey Ryan, when you say intake, are you talking the throttle body and AC filter gaskets? Or other ares? And how would I check for those leaks?
Old Oct 13, 2015 | 06:24 PM
Lonewolf176's Avatar
Lonewolf176
Don't be so hard on your tuner. If you are still running the stock head pipe the problem comes with free flowing mufflers. They suck air back up the left side which can be a nightmare to get rid of. Short of changing either the mufflers or head pipes you can install one of these in the left pipe to help. Any bike will run so much better with a good tune.
http://www.zippersperformance.com/al...p-stopper.html
Old Oct 13, 2015 | 06:52 PM
rjm-1's Avatar
rjm-1
I've suspected the left side pipe may contribute to the decel popping but have not seen these before, nor have I see any other reference to this item when searching forums for a fix. Might be worth a shot.
Old Oct 13, 2015 | 06:56 PM
rjm-1's Avatar
rjm-1
BTW, what head pipe change might fix decel popping?
And, Has anybody tried Zipper's Dual Exhaust Pop Stopper?? This has been around for a long time but this is the first I've heard of it. With so many posts about decel popping, I'm surprised this has not been a suggested fix unless it does not work? But still no posts about it not working either?
I was going to order one, but I figured I'd ask first.
Last edited by rjm-1; Oct 13, 2015 at 08:06 PM. Reason: Addded questions on pop stopper
Old Oct 14, 2015 | 01:11 AM
Lonewolf176
Pretty inexpensive to try the Zippers plug or just use the right size frost plug When tuning I will block the left muffler completely below 15% throttle to get an accurate sample. This exhaust works well
http://www.khromewerks.com/2-2-HEADE...1029-1107.html
Old Oct 14, 2015 | 10:23 AM
Correct, the air intake and filter gaskets. The easiest way to check is to hold something that creates smoke around the area.
