2014 Aircleaner?
Old 10-16-2015, 06:24 PM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
Default 29400159 Adapter Gasket
Originally Posted by p51bombay
The rubber adapter from the SE kit is 29400159. I checked and both the Arlen Ness kit and the Drag conversion filter seem to be made with the rubber bit molded on the filter - could be HD wouldn't let them make a separate part or someone other than Ness is making that SE kit.
Thank you sir!
Old 10-17-2015, 11:23 AM
motolocopat's Avatar
motolocopat
motolocopat is offline
Originally Posted by Route66
So, are you saying that installing an Arlen Ness Big Sucker Kit (with an OEM cover) on a stock 2014 Road King will have no benefit, performance wise?
This Spring I plan to install the following performance parts:
1) Arlen Ness Big Sucker (w/ OEM cover)
2) Vance & Hines Power Duals
3) Vance & Hines Hi-Output Slip-Ons
4) Vance & Hines Fuelpak FP3
Any thoughts, opinions or advice would be much appreciated.
I wouldn't say that it has no benefit at all especially compared to the Big Sucker which is one of the best flowing intakes available. However the stock intakes from 2014 are greatly improved and are not a limiting factor on mild builds like they previous ones were.
What I would say is that of the parts you have listed I'd drop the Big Sucker and the FP3 and get a higher end tuner that will be better at growing with the bike come cam and or big-bore time. Fuel moto guys do a pretty good job of sending out their PCV with a preliminary tune for most common setups and the V&H stuff you are selecting definitly fall into that category. Afterwards they will send you tune updates as you/if you/when you change/add components. The PCV will autotune also and there are a lot of local tuners around who are familiar with them for when you decide to get it up on a Dyno.
Old 10-20-2015, 04:34 PM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
Here is the link to the PDF file for the Installation instructions of the stage one air cleaner which includes all part numbers
http://www.harley-davidson.com/app-c...ts/-J05717.PDF
Old 10-21-2015, 12:51 PM
Route66's Avatar
Route66
Route66 is offline
Ok, thanks for the advise!
Old 10-21-2015, 08:13 PM
Route66's Avatar
Route66
Route66 is offline
Found this interesting comparo...FuelPak vs Power Commander V.
https://www.hdforums.com/forum/gener...mmander-v.html
eviltwin69
2014-2023 Touring Models
04-04-2015 12:34 AM
Slim Stockton
11-12-2013 01:54 AM
jb27
07-02-2013 12:08 PM
Mrawsome21
09-09-2009 07:05 AM
txoval
03-07-2009 01:27 PM
Quick Reply: 2014 Aircleaner?
