Mute radio function
Skratch - as someone who knows audio at the circuit board component level, there's no technical difference between mute and minimum volume. The audio processing IC typically has no boost; it only has attenuation capabilities - if you have the volume set anywhere else other than full volume, you are attenuating.
The only difference between mute and volume is the software that reacts to your different button press. If HK chose to use a volume **** button press as the mute signal, that's still mute even if it isn't labeled, the function is the same.
Moreover, the mute function typically doesn't fully attenuate the signal. It usually reduces by a set decibel amount from wherever you happen to have the volume set... Therefore, if you really want to fully mute, the most certain way is simply to reduce volume completely.
or if they can't give us that, how about a pause button?
