Mute radio function
Old Jan 14, 2016 | 08:50 AM
itsmf's Avatar
itsmf
Default Mute radio function
On a 2009 Ultra,is there a mute function on the handlebar controls? I have the stock HK radio.
Old Jan 14, 2016 | 10:11 AM
azlou66's Avatar
azlou66
My 2008 FLHX doesn't have that function.
Old Jan 14, 2016 | 10:19 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Yes, there is. Put your thumb on the volume control, and hold down. It will drop volume until it's muted. It's been a while since I had an HK radio, because I replace it..... but I think it even says MUTE on the display when you do this.
Old Jan 14, 2016 | 08:09 PM
skratch's Avatar
skratch
^ yep, dumbest thing I've ever seen. turn the volume all the way down and you consider that muted? I guess in the literal sense of the word, but really........
Old Jan 14, 2016 | 08:22 PM
h-d wrencher's Avatar
h-d wrencher
When I still had my HK unit on my 09, sometimes I would just try to turn the radio down a notch or 2 and I would barely touch the down button and it would mute. Didn't know if there was a trick to it that I didn't know or what.
Old Jan 14, 2016 | 09:26 PM
shooter5074
I gave the only correct answer....... Turn the volume all the way down and the display will say MUTE. If you have a better answer, please share it. Otherwise..............................:icon_snowb all:
Old Jan 14, 2016 | 09:44 PM
WB's Avatar
WB
I think this comment is directed at HK stereo, not you..
Old Jan 14, 2016 | 10:02 PM
shooter5074
It didn't read that way. But you could be right......... that's why I only threw a snowball
Old Jan 14, 2016 | 11:53 PM
gusotto's Avatar
gusotto
If possible, it would be noted in your owners manual.
My '07 Ultra manual states while in "Intercom Mode", it will display MUTE when volume is all the way down for Intercom.
Old Jan 15, 2016 | 05:13 AM
skratch's Avatar
skratch
correct. i think it's stupid that if you turn the volume all the way down it says 'mute'. to me, mute means press a button, the volume goes down, press the button again and it returns to where you were. otherwise, you're just turning the volume up and down.....
sorry if you took my reply as a swipe at you, it was definitely not meant that way.
