Engine and Security Light
Old May 12, 2007 | 07:44 PM
Piper's Avatar
Piper
Default Engine and Security Light
Hi Everyone: Just got back from a 300 mile run. About half way through, the engine and security lights (the two that spool up on the speedometer gauge) started coming on and off intermittently. Continued for the rest of the trip.
I'm thinking a sensor - am I in the right area?
The bike - 2002 Road King Classic
Appreciate any help.
Old May 13, 2007 | 07:12 AM
PapaTravis's Avatar
PapaTravis
Default RE: Engine and Security Light
I don't have an answer, but will bump this post to the top to see if anyone can help out. You never know, this might happen to me, and I would like to know the cause and solution if it ever occurs.
Old May 13, 2007 | 08:16 AM
Bigredone's Avatar
Bigredone
You need to have a dealer pull the codes. Could be minor, could be serious.
Old May 13, 2007 | 09:21 AM
StreetGlide2006's Avatar
StreetGlide2006
ORIGINAL: Bigredone
Depending on the year of the bike the code is easy to read. On newer bikes you can hold the odometer reset button in while turning the ignition to on and it will go into the diagnostic mode. The odometer will read out different code numbers then by continuing to push the button through the different sections. Directions and code information can be found in the DYI or electronics sections of this forum.
Ride Safe,
Mike
Old May 13, 2007 | 09:22 AM
peppi's Avatar
peppi
ORIGINAL: Piper
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector.
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A “trip†consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)
10 24 Loss of vehicle speed
10 33 Loss of vehicle inhibit motion
10 43 Loss of power train security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sen
Old May 23, 2007 | 02:38 PM
Piper's Avatar
Piper
Hey again - had the bike to the dealer (which was a bigger problem than the problem). Living in SW Ontario - checked with the Hamilton Harley dealer - booked solid for 4 weeks, checked Toronto Harley - booked solid for 3 weeks, tried Kitchener Harley - no problem - bring her in. It's about a 50 mile run and no lights came on - they pulled the codes - a wire is grounding somewhere. They say "the last time we had that code it was 10 hours to find it" - at $ 90.00/hr shop time - I asked for the bike back. Drove home, drove all weekend - nothing. Whatever wire WAS grounding, has found it's way back to where it should be, and that's good enough for me!!
FYI if you ever have this happen, that's what the problem is.
Chaseg08
Sep 13, 2012 10:46 PM
scrawfordFLSTC
Aug 21, 2012 07:08 PM
oderonimus
Aug 4, 2011 07:23 AM
happyfeet
Mar 23, 2010 08:33 PM
earlehd
Apr 6, 2008 07:33 PM
