S&S 106 big bore kit
I have decided to install the 106 s&s big bore kit to my 2007 street glide, however I am not sure if it will work well with the 551 easy start cams currently installed in my bike.
Anybody made the same combination 106 /107 kit with the said cams ?
also installed s&s power tunes with vance and hines slip ons, s&s stealth air cleaner and thundermax ecu.
I am looking for low end torque.
Should I do the heads as well?
Thanks
Thanks
I'm running that set up, but thinking about swapping the cams for 583's. The 551's haven't run smoothly for me, and I wonder if the compression ratio is too high for the 551's. On the website, 551's are for less than 10-1 compression ratio, which in the CR for the set-up with stock heads.
I think if your crank was going to go, it was going to go, 106 or not, I doubt the 106 killed your crank. Tons of people running 107s, 120+ TQ, no issues. I've got 20K on my, still going quite strong...
It's hardly a fair comparison, but my S&S Evo 107" came with 585 cam and the torque curve is wide and smooth. Great performance for a heavy Glide!
obxmidgett
2014-2023 Touring Models
06-11-2016 10:29 AM
