Clutch cable adjustment, too long?
Length of cable has no bearing on whether or not it can be adjusted. Unless it's to short but that's obvious. You may have to take the trap door back off and make certain the ramp is pushed all the way back.
you need to be sure that the ***** are set in the ramp- make sure by pulling in the cable with pliers that the clutch rod is moving the clutch pack against the spring.
if is is and you have positive feeling all the way out and all teh way back, then you'll know that all is good under the trap door...if there is slop, just doing this a few times should set the *****
mike
mike
