O2 sensor thread pitch
Do you have a tap and die set? They usually have gauges to check the pitch at least mine does but sorry the set is at work and the bikes are in the garage why did you strip the thread if so that sux ...good luck
the 18mm ones are the same as a spark plug, 1.50
goes back to the days when we used spark plug anti-foulers (drilled out) to back the 02 sensors out of the stream a little to keep them from tossing codes
https://www.amazon.com/Lisle-12230-O...TBKW18XKVPAJW3
https://www.amazon.com/Irwin-Hanson-.../dp/B002V06UJC
