3" taller bars
Old Oct 16, 2016 | 09:53 AM
kfchd's Avatar
kfchd
Default 3" taller bars
2011 Flhtcu.can you use 3" taller bars without buying new cables and brake hose?
Old Oct 16, 2016 | 06:11 PM
Keithhu's Avatar
Keithhu
Whats more important: keeping old cables or being as comfortable as you can be?
Old Oct 16, 2016 | 06:44 PM
Cozz's Avatar
Cozz
Default Ten inch
The general consensus is that ten inch bars will work with stock wires and cables, possibly requiring some re- routing. Anything taller, will not. Taller bars are on my to do list also.
Old Oct 16, 2016 | 06:59 PM
mgray1's Avatar
mgray1
So will the HD Reach bars work with minimal additional parts?
Old Oct 16, 2016 | 07:02 PM
kfchd's Avatar
kfchd
[QUOTE=Keithhu;15600072]Whats more important: keeping old cables or being as comfortable as you can be?[/QUOTE
I don't really care if I have to get cables or not. Just getting a consensus of what I need. If I need new cables for 10". Then I will probably go 12".
Old Oct 16, 2016 | 07:28 PM
Cozz's Avatar
Cozz
Maybe someone who has done exactly what you want to do will add their two cents.
Old Oct 16, 2016 | 07:30 PM
Helomech74's Avatar
Helomech74
I recently installed 12" bars using stock hydraulics lines and NAMZ plug and play wiring harnesses. No issues at all.
Old Oct 16, 2016 | 08:04 PM
MURPHCC1's Avatar
MURPHCC1
Got the 12" Yaffe Monkee bars from Hill Country Customs.....came pre-wired thru the bars with all new cables.......was originally looking at 10"........ a few on here suggested I go to the 12's..........so I did...and I couldn't be happier!!
Old Oct 16, 2016 | 10:38 PM
tully_mars's Avatar
tully_mars
I put 3" bars on my flhtk this year and bought extensions for the control wiring, clutch and brake cables were fine and nothing done there. It can be done with stock control wires, but they are likely to be under some stress during install and potentially afterwards so I didn't want future issues and bought extensions from Moco.
Old Oct 17, 2016 | 01:20 AM
Guntoter's Avatar
Guntoter
My advice on cables, do not use the Drag Specialties/Motion Pro/Bikers Choice, etc clutch cables. They are not sealed at the transmission end and will eventually leak oil out between the housing and fitting. I put 2 on before I learned and switched brands (Magnum Shielding). I also plan to replace my Motion Pro throttle cables too over the winter to match the Magnum clutch cable. Magnum are far superior cables also, just lube them good with spray silicone for best results.
Scott Allen Vermilyer
Jan 21, 2025 08:07 PM
legionxxii
Nov 9, 2021 01:31 AM
eafxstc99
EVO
Mar 4, 2015 06:05 PM
loosnut
Jul 1, 2011 09:40 PM
swensos
EVO
Mar 2, 2011 01:09 PM
