HowTo make Passing Lamps work on both low & high beam
Old Dec 12, 2022 | 09:48 AM
  #51
jake24lt's Avatar
jake24lt
Diag4Bike does it as well.
Old Dec 12, 2022 | 11:02 AM
  #52
skratch's Avatar
skratch
Originally Posted by Andy from Sandy
I think this is what is done with the BCM
Fog Light (Auxillary)
This feature when enabled will tell the BCM to turn on your Fog Light (Auxiliary) when your high beams are turned on.
(NOTE: Touring models aux lights are controlled by the BCM, auxiliary lights have a B/BK wire that extends all the way to the BCM, which gives it control. Softail FLSTC models, fog lights are controlled by a physical switch. That switch is powered by the same BCM line as the headlamp. This means that due to the wiring in the motorcycle this feature is limited on softail models).
https://manual.technoresearch.info/m...nable-disable/
As to cutting and splicing it might seem such an easy thing to do but will be a pain to put the bike back to stock, IMO. I would get the harness lead or make my own.
with a can bus system, you do not want to be cutting and splicing. could open you up to a whole lot of unintended consequences.
Old Dec 12, 2022 | 11:55 AM
  #53
stanley88's Avatar
stanley88
Originally Posted by cycle7447
Sort of hard to believe your dealer is not aware of this (unless you live in a state whereby such is not allowed)
My suggestion - go back and talk to the service manager. Simply tell him/her that when the low lights are on, you can turn the driving lights on. When you switch to high beam, those lights turn off. Let them know you want them to stay on. If he is not familiar, you might try a different dealership.
Just as an FYI, when I got my last new bike in 2021 and reminder the dealer to do this, he told me that they customarily set this up on every bike
I have 5 dealers in the area, I’ll try each of them. The kid I talked to maybe seemed like he was new and didn’t know what I meant. I told him on 14 and up bikes in the digital tech you can enable the passing lamps to stay on with the high beams and he said no I don’t think that’s able to be done. I was already having a bad day so I just said ok and walked away, I didn’t wanna make the kid feel stupid.
Old Dec 12, 2022 | 01:28 PM
  #54
RKZen's Avatar
RKZen
Unless he's an experienced service advisor, they normally learn from the tech guys. I'd call another dealer, and if they say yes they can, you're in luck. Oh, and don't bring the other 2 heads.
Old Dec 12, 2022 | 02:16 PM
  #55
tpcowfish's Avatar
tpcowfish
Had it flashed on 14 fltk, free bought last bike ,21 fltk from a different dealer, asked them to flash, told me $50, turned it down,
RonaldL
Aug 12, 2016 04:05 PM
cnnesseth
May 4, 2013 09:24 PM
aladdin757
Electrical/Lighting/Alarm
May 2, 2013 07:56 PM
joflewbyu2
May 2, 2011 11:54 AM
ozzy07840
Mar 13, 2008 05:57 PM
