Necessary to change brake fluid every 2 years?
Received 2,193 Likes
Received 2,526 Likes
GalvTexGuy (06-26-2017)
Do As You Please
A braking system is a SEALED SYSTEM! While air and moisture are both able to contaminate brake fluid, if the brake system hasn't been compromised my question would be, how in the world could the brake fluid go bad? While there could be no harm in doing a flush I simply say that it I believe it to be totally unnecessary!
As far as ignorance being bliss, my reply would be that knowledge is power!
My background includes 38 years as an automotive parts distributor and automotive shop machinist. I've run a machine shop that specialised in reconditioning cylinder heads thru custom engine building. We also rebuilt our own lines of alternators and starters.
ETA: Just because people have neglected, or done something a certain way for years, doesn't make it the "right way". Advancement are made everyday. Embrace it. Old school methods don't always translate to modern tech.
The following 2 users liked this post by Buelligan666:
Dynamick (06-27-2017),
From_Behind (06-27-2017)
Those that think their brake fluid will never go bad are taking risks that they don't need to because of such a trivial maintenance item.
On my trike the front system seems to just get a little dark colored. The rear system for two changes 4yrs. has been totally black fluid. Still works, but I bet the boiling point is about the same as water.
I thought maybe the seal was bad on the lower master cyl. but changing it didn't make any difference. The system doesn't loose any fluid at all so there isn't a leak anywhere.
I can tell ya it isn't BS ! Why take a chance ? It is cheap & easy to do. Your brakes might work just fine until sometime when you need them the most & under heavy braking the fluid boils & you have a failure. It happens in an instant !
I installed EZ bleeder bleed screws in so it is a one person job.
I use my myti-vac if I have the system open for repairs. But otherwise I use a 100cc syringe to fill the lower master, & the EZ Bleed screws . Total time is about 1/2 hr.fof front & rear systems.
Vehicle hydraulic systems are not sealed, which is why the atmosphere can get in and water penetrates the fluid, degrading it.
Ignorance isn't bliss, it's a liability!
