how to adjust clutch cable slack on 2014 flhr
Which Clutch ?
If there is a small fluid reservoir next to the clutch lever, then it is hydraulic and cannot be adjusted. If it is cable driven, then there is a black accordion sleeve that covers the cable adjustment. Just grab the sleeve and pull it up or down to expose the adjuster.
If I was going to adjust the clutch, I would start with the clutch pack, not the cable.
