Noisey Primary
Old Aug 4, 2017 | 11:41 AM
cajun1957a's Avatar
cajun1957a
Default Noisey Primary
Any way to quiet a noisey primary chain? Adjusted to 5/8 cold. Checked in three different locations on the chain. Compensator is tight, and running lucas primary oil. Tried formula as well. Bearing is good and the shoe is not warn. Just seems loud when oil is hot.
randy
Old Aug 4, 2017 | 11:26 PM
Veekness's Avatar
Veekness
Maybe a new chain...looks like you covered the bases...
Old Aug 5, 2017 | 01:20 PM
CSS899's Avatar
CSS899
Are you sure its the chain? A description of the noise would help. Is it a whirring noise, clattering, etc? Could be the chain or coming from the clutch area? My primary was a little noisey after I installed the Baker Att. Adj. for the first 1000 or so. After that it quited down.
Old Aug 5, 2017 | 03:23 PM
cajun1957a's Avatar
cajun1957a
Definitely not coming from the clutch. Stethescope at the primary I hear noise, I hear a noise at the rocker boxes, I hear a noise on the cam chain side. New in there. I really don't hear it at the lifters. I cant isolate it but when the motor is hot I don't here it hardly at all until the primary is hot then I hear it. I'm lost.
randy
Old Aug 5, 2017 | 03:29 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It's the uneven firing order of a V twin Harley. That inconsistent surge of power makes the compensator make that noise that absolutely annoying noise that drive some crazy. Get over it. It won't hurt anything. It's like fixing that idle vibration. If you don't love it, get a metric.
Old Aug 5, 2017 | 03:52 PM
cajun1957a's Avatar
cajun1957a
Rip, I have had this bike for two years. I bought it used with 29k-km on it. It now has 40k. The noise just started a month ago. I listen to my bike. Probably more than I should but I know when something has changed and something has.
randy
Old Aug 5, 2017 | 04:10 PM
btsom's Avatar
btsom
Many compensators in your vintage bikes were replaced under warranty when they became noisy. The factory seems to have finally found that loss of spring pressure is causing the problem. There is a shim pack available which can improve the spring pressure in the comp and quiet it down. The shim pack is just a few dollars but a new primary cover gasket is over $40 making this a somewhat expensive experiment. Should you decide to go this way, check the hub area of the compensator for fretting (a red coating of fine dust looking like rust) which is common in the earlier designs. That finding would suggest a compensator replacement. The latest style has also suffered from weak springs and one guy reported adding in his old smallest size belleville spring to the new spring stack and that immediately quieted his new comp. which had become noisy in a few thousand miles.
Old Aug 5, 2017 | 09:14 PM
Jackie Paper
randy
New noises could just be a problem. That adds a whole lot to the thought that should have been in your first post.
My primary has been apart 4 times in 50K for noise. Twice by the dealer under warranty and he never did fix the real problem of a stripped spline on the alternator rotor. Then I fixed it and again when I put an auto tensioner in it. Only to realize my chain had a lot of uneven wear (typical of a chain) and that let it be tight and loose in places and made even more noise with the auto tensioner. So I went in a fifth time and took it out.
Now with that hunting idle and between 1/2 and 3/4 slop in the chain, it sort of sounds like a tiller in a gravel bed when hot at a red light. But only at idle.
It's fine at speed. That is all that counts.
You need to add a signature line like my bike line so we know what model you are talking about.
Old Aug 6, 2017 | 02:15 PM
cajun1957a's Avatar
cajun1957a
Would a bad compensator be quiet while the engine and primary are cold and make noise when only hot? The sounds I hear are when the primary and engine are at operating temp, not cold
rand
Old Aug 6, 2017 | 04:17 PM
cajun1957a's Avatar
cajun1957a
here it is
randy
