944 progressive rear shocks
Old 09-03-2017, 07:06 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
Default 944 progressive rear shocks
Mounting the 944 with the adjuster cup at the bottom. My question is does that cup hold water? Here in the Pacific Northwest it's not if you're going to get wet it's when.
Save the there is better shocks out there Theory. I read the forums a lot I just want to know if they hold water. Unless you can actually convince me of a 12 in shock that be perfect for my shortnes.
Old 09-03-2017, 09:30 PM
MotoJockey's Avatar
MotoJockey
MotoJockey is offline
Received 3,115 Likes on 1,281 Posts
Soooooo......... I got's ta know...... why are you mounting the shocks upside down? Do they not fit on your bike with the adjuster on top the way they are supposed to be mounted? Just wonderin'......
Old 09-03-2017, 10:43 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
You can in fact install them either way. Check out mounting directions per Progressive for bikes with detachable sissy bars or detachable solo luggage rack.
I am not trying to install anything on my bike the wrong way in fact I do not even own 944s. I have looked into the 944 shocks which brings me back to my original question.
Old 09-04-2017, 06:54 AM
leachman's Avatar
leachman
leachman is offline
ha ha.....
Old 09-04-2017, 07:23 AM
MotoJockey's Avatar
MotoJockey
I see....
Like I said..... just wonderin'
Old 09-04-2017, 07:27 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
V-Twins & Bowties is offline
As far as pooling dunno. I installed them on my Classic and I have no complaints.
Old 09-04-2017, 07:33 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,232 Likes on 1,631 Posts
Installed 940's on my 09 FLHX and had rear quick-mount on bike...shocks fit fine mounted w/adjustment cup upright (like normal install). Is there a reason why you think the 944's need to be mounted the other way (e.g. upside down) on your bike. Both ends of shock are pretty similar diameter...
Old 09-04-2017, 09:10 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Red face
From the instructions:
"These shocks can be mounted with the adjuster at the top or bottom. However, we recommend the shocks be mounted with the adjuster at the top for ease of spring adjustment."
All their illustrations show them the same way up. My concern would be of water getting trapped against the seals, but in any event installing them adjuster-up will solve all such queries. Why swim against the current?!
Old 09-04-2017, 09:22 AM
frenchbiker's Avatar
frenchbiker
frenchbiker is offline
They can be mounted either way. They are mounted upside down on my Triglide because you can't access the adjustment ring if it's on top unless you take the wheels off.
Old 09-04-2017, 07:08 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
YouTube videos show accessories hitting the adjuster when they're mounted right side up. The directions I see on Progressive site recommend adjuster at the bottom on my bike. I am really not trying to mount something wrong on my bike or swim against the current. I have not even made up my mind on 944 s. I have been thinking about JRI to. But I'd rather just avoid the drama of a shock buying experience. LoL. If you know what I mean.
Quick Reply: 944 progressive rear shocks
