hard shifting
Old Sep 19, 2017 | 11:42 AM
1999flht's Avatar
1999flht
Stage II
Default hard shifting
1999 flht, trouble sifting from first to second and through the gears, with bike off, shifts fine.
Old Sep 19, 2017 | 12:18 PM
Boomer1143's Avatar
Boomer1143
I would start with a proper clutch adjustment and see if the shifting improves.
Old Sep 19, 2017 | 01:06 PM
BB59's Avatar
BB59
The internal clutch adjustment is the first thing to check. It may also be time for a new clutch depending on your mileage. 1999 is a while ago. At about 120,000 miles my stock clutch basket was totally shot. The slots in the clutch basket were so worn and saw toothed that the clutch plates did not slide freely when the clutch was disengaged regardless of the clutch adjustment. This caused the exact same problem you are describing.
I replaced the entire clutch assembly with a Rivera Primo Unit.
mgmmgm
Dec 23, 2023 10:38 AM
bladeguy
May 20, 2021 09:36 PM
cvaria
Apr 21, 2017 12:08 PM
texacon
Jul 18, 2011 07:32 PM
Pippeis
May 27, 2006 12:36 PM
