I have notice the passed few times I changed my oil the drain plug was not turing smoothly. Today it just kept turning and when I pulled it out I had threads on the drain plug. What are my option to fix without removing the oil pan? 2007 Street Glide
Probably going to have to get a self tapping drain plug and go slow. Then take some old oil and fill it up, and drain it. Do that a couple times to remove any metal bits, but it's not a guarantee. Smartest thing would be to remove the pan and clean.
THanks for the comments. I have changed the oil 21 times. Always used a torgue wrench, I can say the same for the dealer when I had my oil changed in Reno. Can anyone tell me what size self tapping I need to buy?
Also, IMO, don't use a torque wrench on oil pan plugs. Grew up on farm, changed oil on many types of motorized equipment/vehicles (combines to minibikes) and never in my 55-yrs have I ever stripped a single drain. Get the tight "feel" and you're good. No need to torque...you see the results.
Is there enough room if you lay the bike on its side to use the timesert product? Looks like it is possible with a left handed drill. Thoughts? Do you know what size timesert I would need to buy?
don't use a torque wrench on oil pan plugs ... I have to agree with this ... especially one with an o-ring. Snug it up and call it done.
