Pin number
If you don't have the Owner's Manual you can get it here. Scroll down to "Owner's Manuals". You will require your vehicle's VIN.
If you bought it from a dealer, surely they would be of more assistance then you can get here? And they could sell you a FOB, program it, etc..
Ummmm he asked a dealer if they had the PIN and they didn’t, and his post here also leads me to believe that they didn’t tell him how to reset it. However, multiple people here have pointed him in the right direction. Seems like this place helped him more so far.
The rider can change the PIN at any time. Refer to Changing the PIN.
Changing the PIN
STEP
NO.
ACTION WAIT FOR CONFIRMATION NOTES
1 Select a 5digit
(1 thru 9) PIN and record on the wallet card
from owner's manual.
2 With an assigned fob present, turn the engine stop switch
to OFF.
3 Turn the ignition switch to IGN.
4 Cycle the OFF/RUN switch twice: RUN OFF
RUN
OFF
RUN.
5 Press left turn signal switch two times. ENTER PIN will scroll through the odometer
window.
6 Press right turn signal switch one time and release. Turn signals will flash three times. Current PIN
will appear in odometer. The first digit will be
flashing.
7 Enter first digit of new PIN by pressing and releasing the
left turn signal switch until the selected digit appears.
8 Press right turn signal switch one time and release. The new digit will replace the current in odometer
window.
9 Enter second digit of selected PIN by pressing and
releasing the left turn signal switch until the selected digit
is present.
10 Press right turn signal switch one time and release. The new digit will replace the current in odometer
window.
11 Enter third digit of the selected PIN by pressing and
is present.
12 Press right turn switch one time and release. The new digit will replace the current in odometer
window.
13 Enter fourth digit of new PIN by pressing and releasing the
left turn signal switch until the selected digit is present.
14 Press right turn switch one time and release. The new digit will replace the current in odometer
window.
15 Enter fifth digit of the new PIN by pressing and releasing
the left turn signal switch until the selected digit is present.
16 Press right turn switch one time and release. The new digit will replace the current in odometer
window.
17 Turn the engine stop switch OFF, then turn the ignition
switch to OFF.
Pushing the engine stop switch to
OFF stores the new PIN in the
module.
Security Status Indicator
Changing the PIN
STEP
NO.
1 Select a 5digit
to OFF.
RUN
OFF
RUN.
window.
flashing.
window.
is present.
window.
is present.
window.
window.
window.
switch to OFF.
module.
As the previous post indicates, if a working FOB, which can be acquired at a dealer, is handy the PIN can be determined/changed. If as others have stated, having a FOB is important, that is why a dealer can be more helpful?
