Key light comes on when turn signals are on.
Something like this....
https://www.jpcycles.com/product/320-183?utm_term=[315219847839:*%2520%2F%2520product%2520type%2520%3 D%2520%22vehicles%2520%26%2520parts%22%2520%2F%252 0product%2520type%2520%3D%2520%22land%2520vehicles %22%2520%2F%2520product%2520type%2520&siteid=NB_G_ PLA&product_id=320-183&adpos=1o5&creative=42616806730&device=c&matcht ype=&network=g&gclid=EAIaIQobChMIzOHK68361wIVHIGzC h2vuA-3EAQYBSABEgIMQvD_BwE
Did you install a load equalizer for the LED's when you installed them?
I'm not sure. I know on my bike I had problems with the LED's when I installed without a load equalizer. What I did was: I kept my rear turn signals as incandescent lights and the rest of the system works properly now.
Were you running the hazards or single side turn signal?
I upgraded to led turn signals front and rear. I also added custom dynamics smart triple play with equalizer in rear for RTB and BAL1 taillight.
Currently I am getting codes b1121 and b1122 which are turn signal codes. I clear codes but they come back. Another post on here said put some dielectric grease on the bulb.
After speaking with Custom Dynamics, they said"
"This is Normal. When activating the 4-ways, their load equalizer goes into "sleep" mode. In sleep mode, when you activate the 4-way hazards using LEDs, the bike thinks one of the bulbs has burnt out thus triggering the output failure codes. The output codes I am getting are a direct relation to this and is the only drawback to their load equalizer."
CD also commented that other load equalizers don't allow you to use the 4-ways with LEDs because their's can't handle it somehow. It has something to due with burning up the module when all 4 lights are on with LED bulbs. I didn't get this part too much but that's what they said.
https://www.hdforums.com/forum/touri...key-light.html
