Passenger Floorboard Removal Help
Received 47,790 Likes
Thanks for the responses. I know they are torqued, but I am afraid I am going to snap the screw/bolt off. I will give it one more try tomorrow, but it I don't have any luck I will ride it the dealer Monday and ask them to break it free. If they break it, they can fix it since the screws/bolts were installed at the factory. It would not be the first time the factory put too much Locktite on a fastener.
My money is that you can’t get leverage with what you are trying to do. Get the proper sized hex socket, an extension, and a good quality socket wrench. If you have the proper sized hex socket, fully inserted, and neither it nor the bolt head are stripped, it will break loose...and the bolt won’t break.
I recently took my passenger footboards off. The bike is a 2016, I bought used.
That top bolt was a BEAR...! I used a 3/8" socket/wrench and when I muscled it enough to move, it creaked like it was going to snap. I shot the front/back area of the bolt with Kroil oil, waited about 30 minutes and was able to muscle it out...
I saw no reason it should have taken so much force/strength... No corrosion, no cross threading, but a bunch of threadlocker. It looked like that HD, OEM stuff, that comes on some new HD bolts.
Anyways, I used a thread-chaser set to clean out the threads on/in both the bolt and the hole. I put it back together at proper torque w/ blue loctite...
We'll see what happens if I need to ever remove it again.....
