chipped paint on tank
Crap, I was messing with my clutch lever and dropped it against my tank. It took a small chip out of the tank about the size of a pencil eraser. So I purchased some touch up paint from the dealership to hopefully make it disappear, since the bike is only a couple of months old.
My question is, should I just try to sand that little area after I touch it up, with 2000grit wet sandpaper, or just clear coat over it.
Problem is I can see the little "bubble" where I applied the touch up paint. I thought maybe I could sand that smooth before I clear coat.
I don't want to make a pencil eraser size spot a huge messed up area with me screwing around with it.
Any insight would be appreciated.
ddsdoorguy (02-25-2018)
One thing is you have plenty of company as it's safe to assume many of us have had more than one "awww....chit" moment. It's human nature. It's just many won't admit it.
First of all, you know you already messed up and by reading your post it would appear you don't have the painting experience/tools needed to fix this at home. Don't let yourself make it worse. Internet opinions on painting isn't what you need here.
Cheyenne is a fairly larger town. Has to be a paint shop there. You need someone hands-on that has years of experience fixing this type of damage if you want your OEM paint job back. Yes, expect to pay for that advice and possible work. The results will be better and in the long run you'll be happier you did. Clearly this bothers you and if not brought back to original you'll be bummed every time you look at that spot and, more than likely, you will be looking at it a lot.
If you find the cost of repair exceeds your deductible call your insurance company. That's why you pay those premiums. Possible insurance company might just want to replace the tank. Have you priced a new painted tank lately? If not, might want to be seated when you do.
I have literally done that twice. There won't be a third.
I just used the color to build up the hole. Let it dry, hit it with 2000, do another layer - repeat. Then clear a couple times, cut with 2000 again and then polish. Looked good.
The second time it happened I beat myself up real good and took the tank and paint to a mobile touch up paint guy that my local Nissan dealership uses. He fixed it for 100 bucks and it was perfect.
Yep, we've all done it. This is the best advice right here. 100 bucks and you'll never know it was there. If you fix it, you'll see it every time.
