USB port in Street Glide fairing switch housing?
Yeah, that is what I am going to do. I have been looking for a cheap filler blank to use in the build so I don’t screw up the ones I already have, but I will be dammed if I can find one.
Anyone have an extra blank laying around after they replaced with switches? 2010
Received 19,651 Likes
I used a 12v to usb adapter hooked to the battery. Removed tank and plastic top from wire harness. Removed front fairing cover. Ran wire up main wire box through the fairing. and out the clutch cable hole. connects to the phone right in the same location. Easy job.
If you all ready have a Battery Tender connector on it you can use one of these and a regular usb cable. easy.
https://www.walmart.com/ip/Battery-T...&wl13=&veh=sem
Received 8,253 Likes
