Cleaning Tmap sensor?
Old Jul 20, 2021 | 09:25 PM
qfyffe73's Avatar
qfyffe73
Stage II
Default Changing tmap Sensor 2001 Fatboy?
How hard is it to change?
Old Jul 20, 2021 | 09:42 PM
JustDave13's Avatar
JustDave13
Originally Posted by ozzie21
I posted most of this text in another thread about engine temperature sensor problems. I had an issue this year with both my engine temperature sensor and my TMAP sensor. My bike when cold would start OK and seem to idle OK but within a few minutes of getting on the road it would start running really rough, would not idle and often just shut down and also when running it would hunt with RPM surging high then low and high and shut down. I was getting error codes P0117, P0118 & P0113. The P0117 & P0118 have to do with the engine temperature sensor and the P0113 is related to the TMAP sensor. I changed my engine temperature sensor and went for a test ride and it was still acting up. I checked my error codes. No more P0117 and P0118 error code but I still had the P0113 code (TMAP sensor). I checked under the wiring looms and found one of the 3-way soldered connections where one of the wires branched off to the TMAP sensor had vibrated and broken off at the wire going to the TMAP sensor. I added a short length of wire and soldered everything back and shrink tubing all the bare connections. I already had a new TMAP sensor so I swapped out the old one for this new Fueling TMAP sensor. The old TMAP sensor was likely OK but being in there for 8 years I figured may as well change it. Went out for another test ride and now my 120R Trask Turbo FLHX is back to running smooth and strong like it always did. And no more error codes.
Damn.. talk about making it fit.
eglideic
Dec 12, 2018 04:28 PM
bobdog
Apr 6, 2017 02:14 AM
Jack Straw
May 11, 2011 07:57 PM
firefightermike
Apr 13, 2011 10:33 AM
KBFXDLI
Exhaust System Topics
Nov 15, 2008 12:45 PM
