02 FLHTCI Headlight bulb
Old Jun 27, 2007 | 10:48 AM
Mongo40's Avatar
Mongo40
Default 02 FLHTCI Headlight bulb
What type of bulb is used in the headlight on an 02 FLHTC I was going to walk across the street and pick up a silverstar for mine but don't have the bike manual here. Thanks.
Chris
Old Jun 27, 2007 | 11:55 AM
gunrunner's Avatar
gunrunner
Default RE: 02 FLHTCI Headlight bulb
H4 I think, but silverstars are known to fail much quicker in harleys due to vibration.
Old Jun 27, 2007 | 12:22 PM
Mongo40's Avatar
Mongo40
Thanks I was thinking it was just a regular H4 with the three prongs, I've also read that about silverstars failing, but I'll tell you before I read any of that about the failing I've had the samesilverstar bulbin my 1988 Softail for the last two years now and its still working fine, the vibrations on the Eglide aren't anything like they are on that old softail. Thanks though.
Chris
Old Jun 27, 2007 | 03:30 PM
Neckball's Avatar
Neckball
I've had two go out in the last two years so I'm back to running the stock one again. I'll probably just stay with it. On the Silverstar package for the H4 it will say "For motorcycle use" but in my case it didn't seem to make a difference.
Old Jun 27, 2007 | 03:32 PM
Domestic Violence's Avatar
Domestic Violence
yup- what they said
Old Jun 27, 2007 | 09:53 PM
iclick's Avatar
iclick
ORIGINAL: Mongo40
Order some ??/100w bulbs. The high-beam output is considerably better, and I've averaged about 3 years per bulb over the past 10 years I've been using them. You can buy 55/100, 85/100, and 90/100. I have seen some that go above 100w for the high-beam, but that may stress the fuse/breaker. I've had no trouble with the 100w variety on either my '96 RK or this '07 SG. Kuryakyn makes a 90/100w bulb for $9 (clear). I wouldn't buy the blue-tinted variety as the tinting is counterproductive. It cuts light intensity and is a less-visible color temperature.
dub976
Dec 8, 2011 07:43 PM
SPECIAL ED
Feb 17, 2011 05:05 AM
bluedemon06
Apr 13, 2009 05:06 PM
John3:16
Oct 17, 2007 07:34 PM
HaggisMan14
Aug 31, 2006 06:48 PM
