octane
Old Jul 19, 2018 | 09:11 PM
Josephgatto's Avatar
Josephgatto
Stage I
Default octane
I have a 2010 Electra-Glide classic. I am going to Denver Colorado. I have been told that the octane levels in the gas are below manufactures recommendation of premium or 91+ octane. Do I need to add a booster to the fuel for the higher octane
Old Jul 19, 2018 | 09:15 PM
Veekness's Avatar
Veekness
Wouldn't hurt. Suggest Lucas
Old Jul 19, 2018 | 09:47 PM
Pass Rider's Avatar
Pass Rider
I live and ride up here. Actually my house is over 1200 feet higher in elevation than Denver. I ride over passes that are over 10,000 ft up, over Trail Ridge Road that is over 12,000 ft and to the tops of Mount Evans and Pikes Peak both of which are over 14,000 ft. Never had a problem with any of my bikes at any elevation. I always use the highest octane gas available.
One possibility, though...if you have done significant upgrades to the engine (stage 2 or above) all bets are off.
Old Jul 19, 2018 | 09:54 PM
Joe from So Cal's Avatar
Joe from So Cal
I used to run Moroso Octane booster in a street car that had a compression ratio of 13.5:1. It contained a chemical named Methylcyclopentadienyl manganese tricarbonyl (MMT). I used it in concentrations higher than recommended and it left a redish substance on the plugs, enough that I bought a small spark plug cleaner/sandblaster to clean them.
I'm not sure how octane boosters react with catalytic converters. Maybe check on that before using it.
Old Jul 19, 2018 | 11:20 PM
DTTJGlide's Avatar
DTTJGlide
The less air density at higher elevations lowers you CR a little so less octane should be required, that being said almost all of the larger stations have 91 octane gas.
Old Jul 20, 2018 | 12:44 AM
Guntoter's Avatar
Guntoter
Out in South Dakota, when I was there a couple times for Sturgis, it's sometimes hard to find gas above 89 octane. It all worked fine in my bike, but it's a 96 not 103. Fuel mileage sucked, however.
Old Jul 20, 2018 | 11:42 AM
Sparkee...'s Avatar
Sparkee...
I never had any issues finding 91 on a recent trip to Colorado. I always carry some octane boost with me when touring. My Glide doesn't like it when the temps get above 90-100F and needs it even with high octane fuel.
Old Jul 20, 2018 | 12:38 PM
rochkes's Avatar
rochkes
I have 10.5:1 compression in my 103 and have ridden it over 70,000 miles all over this country. I always try to use the highest octane available wherever I am and have never had any problems with any low octane fuel anywhere.
I think octane booster is a joke. Read the label. All claims I have read is if you put in the recommended amount, it will raise the octane .1. That's one tenth a point, not one point. I admit I haven't researched octane booster very much because I have never for one second thought I needed an octane boost.
Dennis
Old Jul 20, 2018 | 12:43 PM
Kingglide549's Avatar
Kingglide549
The only time I have suffered for high octane is the 1st 100 miles into Canada from Ste Suit Marie.
Make sure you gas up in the states or after the first 1oo miles in Canada, which i think is around Thunder Bay...cant remeber so dont hold me to it.
Old Jul 20, 2018 | 02:20 PM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
You should be fine with whatever gas you use.
H-D realizes we don't sometimes follow the recommend fuel they want us to use or is not available when you need to gas up, so they managed to include various sensors that compensate for that.
