Mirror options
Old 01-01-2019, 07:07 PM
DC3TP's Avatar
DC3TP
DC3TP is offline
Default Mirror options
I recently purchased a low mileage 2010 Ultra Classic that has the mirrors mounted on the fairing. I like these mirrors and have ridden another bike with normally mounted mirrors but neither is quite wide enough to get a good view around my arms/shoulders. If I lean to the side a little they are adequate but I’d prefer to find something that allows a good view from either side while sitting up straight.
If anyone has suggestions I’d appreciate it.
Thanks in advance.
Old 01-01-2019, 07:47 PM
DaleMc0622's Avatar
DaleMc0622
DaleMc0622 is offline
Harley has two types of mirrors, the short stem and long stem, my guess without seeing a pictures is that you have the short stem mirrors. If you want to stay Harley, try and find a set of the long mirrors. I had a set of aftermarket ones and recently switched back to oem and am now thinking about the long/tall ones to try for the same reason.
Old 01-01-2019, 08:19 PM
caulk04's Avatar
caulk04
caulk04 is offline
I've found that by adjusting the mirrors in a bit so the inner portion is looking at you, the outer gets a little more reach. Just what I've found.
I run my standard mirrors under the levers on my 10" bars to keep the lines cleaner.
Old 01-01-2019, 08:20 PM
95th 1200's Avatar
95th 1200
95th 1200 is offline
Ultra shouldn't have the "paddle" mirrors on the fairing, OE is stem style mirrors mounted on the bars. Someone probably switched them at some point. Regardless, HD offers the "Split Vision" mirror which has a convex on each end, otherwise the long stems may be the way to go as previously mentioned.
Old 01-01-2019, 08:51 PM
DC3TP's Avatar
DC3TP
DC3TP is offline
You are right. The previous owner changed from stock mirrors to fairing mounted. From what I see it looks like stock are the short stem. Assuming the long stem moves them out, not just up, that’s probably a good option.
Old 01-01-2019, 09:28 PM
TheMurf's Avatar
TheMurf
TheMurf is offline
Received 3,673 Likes on 1,671 Posts
If you decide to go to the stock handlebar mounted mirrors, Harley makes mirror extensions that raise the mirrors up. They are the first thing I install on all my Harleys since the 80's. You can find them in the accessories catalog. They fix your view problem and they are not expensive. I also attach blind spot mirror lens to the top outside portion of the bar mirrors.They stick on and allow you to see objects in you blind spots. Both are effective fixes to being able to see along side you and behind you,making your ride more safe.
Old 01-02-2019, 08:58 AM
Oko's Avatar
Oko
Oko is offline
Received 3,870 Likes on 1,456 Posts
I went with HD long stem mirrors on my ‘16 FLHTK. And surpisingly, it’s the stem with mirrors for under $60. I sold my stock for $20.
One of the few HD items under a hunnadollars.
Old 01-02-2019, 11:35 AM
TheMurf's Avatar
TheMurf
TheMurf is offline
Default Mirror Extensions
The extension kit is on 91907-87 , in the harlHa accessories catolog. 30 Bucks.
DC3TP (01-02-2019)
Old 01-02-2019, 03:12 PM
cc8251's Avatar
cc8251
cc8251 is offline
Kuryakyn makes mirror stem extenders that move them up and out. They worked for me.
DC3TP (01-02-2019)
Old 01-02-2019, 08:19 PM
Geezr Glidr's Avatar
Geezr Glidr
Geezr Glidr is offline
Yup. cc8251 has the solution. I have a 16 Limited, and all I could see was my shoulders. Those extensions are easy to put on, and the did the trick for me.
Quick Reply: Mirror options
