I always liked the look of the "103" derby cover on my old '11 Street Glide. My current ride, a 2015 Ultra Limited has a plain derby cover. I would like to put a "103" one on my Limited. I am thinking that it will work fine. Am I correct?
twin cam derby covers will work. where you will come into problems is the narrow primary uses a bigger derby cover. so a regular primary derby cover is not interchangeable with the narrow and vice versa.
Didn't all the '16 model touring bikes have the narrow primary cover?
I have a 103 derby cover Im not using. The chrome isnt flawless but its not too bad. I can post some pics when I get home. Where are u located? Gilbert, AZ here.
Your 2015 could have either narrow primary or the old standard wide primary. Most likely it is a wide. Covers are a different size If cover is 8 inches you have a narrow if it is smaller you have a wide. Just get the right one.
2016 and up Tour have the narrow, some 2015 had the narrow also. they put the narrow on many of the Low models.
