Harley 110” head info.
I’m considering purchasing a set of take off 110 heads for a 117” build, the heads will be then going in for porting and I would like them at 84-85cc’s...
I have a few questions so I’m going to just list what I’m trying to figure out below... any questions anyone could help with would be great.
the bike is an 09 FLHX going 96”-117”
- difference in liquid cooled vs air cooled heads on an air cooled bike.
- removing ACR’s and adding manual, is it possible.
- can these be milled to 84-85cc’s.
-are there any years/casts that should be avoided.
Thanks
Thanks
I take it you're asking about liquid-cooled 110" heads? I can't answer that but why would you want to change to manual CRs, especially if those heads already have provision for ACRs? I've been using ACRs for over ten years and they are just great! Also manual ones have to be accessible, so adding them may well require fresh mounting holes.
I have ACRs on my 1990 Evo, adding the wiring was simple enough, although it did come with my S&S engine!
Using manual releases isn't a bad idea, but adding the ACR harness is not too hard. Did have to have the ECM flashed though which meant bringing it in to a dealer or doing it yourself with a PV or TTS or similar.
https://www.harley-davidson.com/stor...E&gclsrc=aw.ds
Do get air cooled heads to avoid issues.
grbrown (01-20-2019)
Thanks
Thanks
