Breather oil return/Rockouts
Hello all,
Ive got a thread going on here about my adventure inspecting cam chain tensioner shoes, and wanted to ask another question that has to do with the top end. I’m reusing push rods, so I have the rocker covers, rockers, and breathers off. A buddy reccomended Rockouts, so I’m considering those.
I have heard about drilling the oil return holes larger to ⅛” for better oil return.
I’ve never had an issue with oil outside of the bike, before so I don’t have a problem to fix, but not knowing exactly what the purpose is, I’m curious if I should do it to improve oil returning?
can somebody help explain exactly what the purpose is, and what exactly to do?
Also, pros and cons of Rockouts?
thanks.
thanks.
ROCKOUT Rocker Products (04-29-2019)
The bigger holes just allow any oil laying in the top end to get back down easier and minimizes the chance of the oil blowing out the breather. If you have top end noise caused by the rocker shafts hitting the bolts that hold the rockers on then the rock outs will cure that. I put them in mine but I knew as soon as I pulled the shaft it wasn't the cause of my noise but I put them in anyway. You have it apart so look at the shafts where they pass by the bolts and if there are witness marks them the locks should eliminate some noise. It is an air cooled pushrod motor that you're sitting right on top of so don't let " normal " noises bankrupt you lol. You'll learn what normal is for your bike then when you hear something that's not you'll know right away. Make sure you follow the manual bolting those rocker holders back down...dont turn a nice easy preventative maintenance job into a motor rebuild project.
Pros... quieter engine, less wear on the shafts/rocker supports, better alignment
Cons.... absolutely none
John @ Rockout
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
John @ Rockout
__________________
NO, they DON'T all do that!
Also on amazon.com...
