Starter button doesnt do anything
Old Apr 6, 2020 | 09:18 PM
BJM's Avatar
BJM
Stage II
Default Starter button doesnt do anything
After replacing handle bars with 14 " apes starter button wont do anything with ignition switch to on but if I turn to acc then back to ignition starter button works
this is a 2007 ultra classic
Old Apr 7, 2020 | 07:24 AM
Zerk's Avatar
Zerk
Well you screwed up, and will have to take it apart until you figured out where.
Old Apr 7, 2020 | 07:54 AM
grbrown's Avatar
grbrown
Exclamation
Unfortunately we have a steady trickle of members who have problems after changing handlebars. There is nothing any of us in here can do except recommend you check your work with great care. You have a wiring error, or a pinched wire or similar, possibly a blown fuse. Have you confirmed that the engine kill switch is in the correct position?
Old Apr 7, 2020 | 07:57 AM
Kawickrice's Avatar
Kawickrice
It could be the switch itself. I had one go out that did this
Old Apr 7, 2020 | 07:59 AM
Zerk's Avatar
Zerk
Once after lubing cables had an issue. Would start after I opend back up, but not after I closed back up. strand of wire was sticking out. Squirted some RTV in there. But you got to find the problem. I was able to trace from inputs to TSSM. Use a meter, or just start looking.
Wayward1200
Electrical/Lighting/Alarm
Nov 15, 2019 09:24 PM
drrot
Aug 15, 2019 12:20 PM
jim70
Nov 16, 2015 05:21 PM
Wildman1967Chevelle
Jun 23, 2011 03:19 PM
rwhite15
Nov 28, 2009 05:27 PM
