2005 Road King Classic EFI U1240 error code
Old Oct 12, 2021 | 06:02 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
Default 2005 Road King Classic EFI U1240 error code
Hoping I can find an answer here. I’m trying to install a new HD Speedo that should be plug and play but I get a U1240, dead data port, error. I’ve traced the wires everything is hot but data won’t transfer. New gauge powers up but the transfer never happens.
ideas?
Thanks
Old Oct 12, 2021 | 06:46 PM
Highclasshobo's Avatar
Highclasshobo
You could try cleaning the data port with some electrical cleaner. (Must be electrical cleaner specifically) maybe one of the pin holes got some gook in it. Or maybe one of the wires in the harness has a break in it. So hard to tell sometimes with wires even if they "look" good they can still be broken inside the pristine looking sheathing.
Old Oct 12, 2021 | 06:50 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
I’ve traced and tested continuity for all the wires in and out of the data port. Everything is live and continuous.
Old Oct 12, 2021 | 06:56 PM
kel03's Avatar
kel03
Why the speedo change, did you have that error code prior? Sounds like a connection not making contact.
Old Oct 12, 2021 | 07:08 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
Old Speedo, the decal gets hot, puckers and stops the needle. Not sure about the error. Didn’t have the need to lol. I’ve removed and relooked the TSM. I had a TSSM and thought that it might be the problem but after getting the old TSM locked back in I still get the U1240 code. From the TSM.
Old Oct 12, 2021 | 07:22 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
New gauge powers up, lights up, says no cal, then shows the transfer icon and 0. Never transfers.
Old Oct 12, 2021 | 07:25 PM
Highclasshobo
Are you running a tuner of any sort?
Old Oct 12, 2021 | 07:31 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
No. Stock ECM, old changes made we’re adding the TSSM. did the 30 minute password sync and everything was working fine.
Old Oct 20, 2021 | 04:53 PM
SWMOrider's Avatar
SWMOrider
2nd Gear
Default The plot thickens
Just spent a half day vacation to ride the the Harley dealership to have this fixed and installed. Low and behold, since the speedometer/tach that is in the bike now is a HD part but not the “STOCK” speedometer I’m SOL. Spent $315 on the new Speedo, get to order another stock Speedo from HD with my mileage loaded on it for another $350, then the new Speedo will sync and work.
There are no words to explain how pissed off I am at this point with HD double dipping us owners. Might be time to look at an Indian.
Kwadman
General Topics/Tech Tips
Jul 11, 2018 07:18 PM
hdiceblue
May 24, 2017 08:22 PM
Nakkedbiker
Motorcycles For Sale
Jun 30, 2010 06:57 AM
Nakkedbiker
Apr 11, 2010 03:18 PM
dix
Sep 7, 2007 08:16 PM
