Drain plug chain case
Old Nov 7, 2021 | 01:23 PM
pointblank's Avatar
pointblank
Default Drain plug chain case
My manual indicates to screw in the plug tight to .160 - .180 but mine is NOT tight. It's loose no matter. The threads is NOT stripped.
it's always been that way.
As well why would there be a small ball on the end of the plug....and the end of it spins as well??
What I've been doing is applied thread locker to the threads and then a little silicone to the end to insure it does not come out.
any ideas??
Old Nov 7, 2021 | 01:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Harley Part Number 739.
The little ball in the end is a magnet.
It is a tapered pipe plug, over torquing can crack the case.
The service manual says to install so that it is .160-.180 above surface of case, I have never checked how far above the surface of the case it is when installed.
I have always wrapped the threads with teflon tape and snug down.
Old Nov 7, 2021 | 02:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I use a PTS (pipe thread sealant) on my 02 Dyna primary drain. The PTS seals and prevents the plug from backing out. If your plug isn't snugging up at all it's possible the case could have a small crack at the threads. The primary is non -pressurized and the oil doesn't normally go any wear else, i.e. tiny passages.
Old Nov 7, 2021 | 05:49 PM
pointblank's Avatar
pointblank
Next time I will check the threads. It's just been that way since I bought it.
guess I will not worry about it.
Wishbone68
Jun 30, 2014 04:40 PM
hardheaded
May 25, 2013 06:25 PM
Frankster69
Sep 21, 2008 10:20 AM
Dancemax
Aug 8, 2007 05:16 PM
Dancemax
Aug 6, 2007 07:51 PM
