1989 FLHTC signal module
Old May 23, 2022 | 08:31 PM
flhtc89's Avatar
flhtc89
Default 1989 FLHTC signal module
I'm getting annoyed with my turn signals cancelling whenever they feel like it. The bikes got its original turn signal module. A while back i disconnected a wire from it that i thought might solve the issue but it didnt help.
Now I'm looking at new modules but they're all self cancelling. The badlands one self cancels after 9 seconds.
Are there any modules out there that aren't self cancelling? so i would momentarily press a signal button to start flashing and momentarily again to cancel
Old May 24, 2022 | 02:42 AM
Allenz's Avatar
Allenz
I also have a 1989 FLHTC. I had the same problem only mine would cancel sometime and sometime I would have to press the button to stop the turn signal. Sometimes the turn signals would not work at all. Shut down the engine & restart then everything worked again. Very erratic. I pulled the wiring connector from the modular, spayed with contact cleaner, pushed the connector on & off several times to be sure I had good contact. Applied dialectic grease to each contact pin with a Q tip. It has been working fine for 4 years now. Just a thought.
Old Jun 21, 2024 | 12:15 PM
Denis 1989 FLHTC's Avatar
Denis 1989 FLHTC
Stage II
Default Turn signal module
I have the same problem with my FLHTC and was curious if you found a replacement module and if you can tell me where the module is located on the bike. Will be happy to share my results after I've cleaned the connectors or if I had to replace the module. Thanks
Old Jun 21, 2024 | 06:16 PM
Dano523's Avatar
Dano523
its location on a bracket by the the top of the steering neck on the front side.
Part number is 68537-89, But since HD not longer has them, used may be luck of the draw, then maybe aftermarket may be the ticket instead.
https://www.customdynamics.com/auto-...le-10-position,
Old Jun 21, 2024 | 06:39 PM
Denis 1989 FLHTC
Stage II
Thank you very much for your help. Looking forward to get this issue resolved.
pepster415
Electrical/Lighting/Alarm
Apr 24, 2021 07:27 PM
javila4747
Jul 17, 2020 08:14 AM
Nick_M
Jun 21, 2020 09:24 PM
divco13
Jan 18, 2014 09:54 AM
larsfum
EVO
Jan 12, 2011 11:02 AM
