Battery bad?
Connect battery once a month (what I do) or as recommended by manual to top it off every 2 weeks. My OEM batteries last about 8 years. Bought 700 miles 2 years old bike that was always on the tender all the time battery need to be replaced next year after purchase.
i don't think the battery tender will help if it needs a charge. I think it's more to maintain a charge. I keep my bikes plugged in when not riding them. And like someone said already, check battery cables. My Heritage was hard to start when I bought it. Guy said he just put a battery in it, so I said it was probably the stator and he took some money off. Got it home, pulled the seat and the cables were loose. For some reason they come loose on this bike once in a while. I should probably try some new bolts but it doesn't bother me enough.
Good point, YZR.
I have had maintainers go bad. If the 2nd one works, throw out the 1st one.
I have 4 smart chargers, 2 for both bikes and 2 for the 2 batteries on my old boat. Batteries are expensive, And like Keithhu I leave mine on 24/7, tenders are not supposed to "boil" batteries if they're working right.
Someone asked earlier, boat batteries are generally large flooded deep cycle.
Bought my 2016 SGS - had a bad battery right out of the gate. It took 2 visits before it was replaced. If your battery will not fully charge than it is separated at the cells. Replace the battery - it is cheap insurance.
Take the advice of charging the battery to capacity regularly. The bike only maintains the battery, but does not charge it to its full potential.
Slow starts, evaluate the battery, replace if need to.
I found batteries last longer if you put the tender on a timer and have it on only 3 or 4 hours a day. Seems like constant tendering cooks them. I know they are supposed to be smart tenders and do float charge and all that, but the guy at the battery store told me to do this and it seems to work.
