Preload
I don't ride 2-up so that's not an issue.
Thanks,
Drop it down a couple of notches and see how it feels.
When you get back, the zip tie should be about 2/3s the way between the shock body and the end of the shaft...
If it is all the way to the end of the shaft, your preload is too soft, and the bumps you are feeling are the shocks bottoming out...
If it has only moved a short distance, your preload is too stiff, and the bumps you are feeling are due to the shocks being too firm, and not softening the bumps...
This video is about using a zip tie on 4x4 shocks, but the technique/theory is the same. Only these 4x4 shocks will hit the top if they bottom out. On your motorcycle, the shocks work in the opposite direction, and the zip tie will be at the bottom end of the shaft if your shocks are bottoming out..
-PH
I’m always riding solo, but many times in the Summer with camping gear. So, I guess adjustability depending upon load will be a requirement.
