Steering stabilizer
Old Feb 20, 2024 | 04:50 AM
clevelandpat1960's Avatar
clevelandpat1960
Default Steering stabilizer
Good morning. Can anyone out there recommend a decent steering stabilizer for my 2008 Ultra Classic? After replacing front stock wheel/tire with a 21 inch, I've noticed a little shake in the forks etc. I checked the wheel and axle, all good there. Thanks!
Old Feb 20, 2024 | 05:40 AM
GalvTexGuy's Avatar
GalvTexGuy
Tire balanced? Steering head bearings?
Old Feb 20, 2024 | 05:44 AM
clevelandpat1960
Default Steering.
Yes tire is balanced and bearings are tight. Thanks.
Old Feb 20, 2024 | 06:06 AM
CoolBreeze3646's Avatar
CoolBreeze3646
1. A steering stabilizer is putting a band aid on the problem.
2. You have changed the rake & trail of your bike by putting a different sized wheel on it.
3. Have you changed the fork length?
4. When was the last time the forks were serviced (removed, cleaned bushings checked, new fork oil).
5. Tire may be balanced but be out of round a bit, check runout.
6. Spoke or cast wheel? Check spokes for correct tension.
7. At what speed does the shake begin? Centrifugal force shake begins at about 60 mph if the tire has a belt or section that is not true.
8. To check for rake/trail shake, when it begins to shake lean forward and lay as close to the gas tank as possible, if it stops or changes you need to adjust your rake/trail.
9. Check your engine mounts and engine alignment in the frame.
10. Check your swing arm bushings.
11. A steering stabilizer may help but you should try to identify the issue causing the shake first.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information and some who speak out of other orifices with gibberish. You will figure out this quickly.
Old Feb 20, 2024 | 06:21 AM
clevelandpat1960
Default Steering
Thankyou for all the input/advise, I will look into all of this and let you know.
Old Feb 20, 2024 | 08:14 AM
RKZen's Avatar
RKZen
When I did 21"s on my '13 King, I also did the fork shocks with a lowering kit to accommodate for the bigger wheel. Could be the issue, could be not but mine rides good.
Old Feb 20, 2024 | 08:21 AM
smitty901's Avatar
smitty901
Steering stabilizer is a tool . It is not a band-aid .
Old Feb 20, 2024 | 09:23 AM
sanman4ever's Avatar
sanman4ever
What size tire are you running on the rear ?
Old Feb 20, 2024 | 09:24 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
@clevelandpat1960 How many miles are on the bike?
Before you go on a search for a steering damper, there are some standard things you should do.
Rebalance the front wheel/tire.
Check the wheel bearings (front and rear).
Disassemble the front end and inspect the steering head bearings, if they have never been serviced the grease will be dried out by now.
I disagree.
On a 2 wheel HD, a steering damper is a band-aid.
Old Feb 20, 2024 | 10:58 AM
CoolBreeze3646
I disagree
The term "Band-aid" was used for cause & effect.
Steering stabilizers have their purpose and use in many applications from Trikes to Super Sport Bikes and yes even some 2 wheel Harley's.
On two wheel bikes it is always best to eliminate other factors before going the stabilizer route as even with a stabilizer track & trail can cause issues that may not be overcome by a stabilizer.
