Compensator ? Help
Old Jun 7, 2025 | 05:40 PM
btsom's Avatar
btsom
If you don't have a new adjuster yet, consider the current auto adjuster. It is considerably improved over the previous design. The teeth are relatively fine, the bottom rail is thicker and stronger and it has two springs, the coil around the shaft for adjusting and springs under the pad to absorb small variations while the chain is running. This eliminates the extremely tight problem with the previous designs. Also, your primary cover does not have the "adjusting window" allowing a tensioner adjustment without removing the primary cover.
Old Jun 9, 2025 | 10:18 PM
BRKLYN1955's Avatar
BRKLYN1955
The part I got is a new spring to add to compensator. Check this video, I bought it from Lyle. For my 07 RK here in Fl.
Old Jun 16, 2025 | 01:08 PM
BRKLYN1955's Avatar
BRKLYN1955
Bump update
i got into it Daturday only to find out my springs had no basket containing them. Turns out that I have a Sreamin Eagle baskets, called up Lyle and left message, today I see he called me yesterday, surprised and I missed the call. I called him this am and he said return part and he would send another spring out. The earliest he would get it out is Saturday, please keep him in thoughts and prayers he was in Denver at Mayo Clinic 🙏🏻 I told him concentrate on his health my spring isn’t important right now.
Old Jun 16, 2025 | 03:18 PM
xikobo's Avatar
xikobo
1st Gear
The primary housing must be opened. Check the tightness, the condition of the teeth, and the tension spring.
Old Jun 19, 2025 | 07:16 PM
Max Headflow's Avatar
Max Headflow
https://youtu.be/pz-uqiYbCj8?si=QeUQDFtMb3B97GcS
Good stuff about the spring placement.
One thing that Lyle misses in the video is the sliding cam splines. They typically wear out and in that case I'd go to a later comp. What happens is the clutch starts to knock..
This area is where the comp wear is..
Old Jun 27, 2025 | 10:19 AM
BRKLYN1955's Avatar
BRKLYN1955
My new screaming eagle spring came in yesterday, driving to my brothers this afternoon and tearing down again. I sure hope this is the culprit.
Old Jun 27, 2025 | 11:00 AM
Rounders's Avatar
Rounders
Originally Posted by Mongo1958
Hi,
Like Mike said, without listening to the bike run, it is hard to tell.
When the bike is hot (or cold), does starting the bike make a grinding noise?
Have you removed the compensator for inspection?
The OEM compensators are notorious for going bad in bikes with the 96ci engine. The solution from the MOCO was to install a Screamin Eagle Compensator, rotor, springs and an oil deflector.
Click the link below.
New Compansator
Doc Harley/ Compensator
The years and such are wrong in the video. Another reason not to trust a guy who calls himself doc. Watch it. Plus he is such a suck up. I wish he would just say harley made a crap design. But it is commercial harley dealer is paying for it.
Old Jul 1, 2025 | 02:59 PM
BRKLYN1955's Avatar
BRKLYN1955
Hello everyone, thank you all for the responses. Got my new spring on screamin eagle kit, turns out doing the same thing from the first time. Turns out after having a friend drive it, he said he'd have to tear down. He checked tension on belt and said it was extremely tight, I touched belt from underside and agreed way to tight. I got home went underneath again to check belt and this time way to loose. Guess what guys and gals, yeah, belt is worn out, that slippage on first second gear and noise, noise is primary spinning without traction, belt worn. Now to order a new belt. God bless and thank you again.
johann batham
May 24, 2022 09:10 PM
superprohero
Jul 11, 2021 03:54 PM
Mikey_P
Aug 21, 2014 12:07 AM
sedouglas
Jan 29, 2012 08:12 PM
KBES BAGGER
Oct 15, 2005 01:36 PM
