07 SG/Tourer Cruise Control Install
RE: 07 SG/Tourer Cruise Control Install
If you have some basic mechnical skills, you can handle it.
You will need to perform the cruise intialization or you will have a
bad lag in the engagement.
Find it here: https://www.hdforums.com/m_81686/tm.htm
My experience was the same as Swipter's, but I didn't find it particularly easy. Murphy's presence was unusually prominent on the night I did this job. Like Swipter, I could do it again in much less time, as the instructions were lacking IMO. Buy a service manual before starting, and look over the install procedure before hand. I got hung up on the pin assignments for the switch, which were not clearly provided in either the instructions or the CC section of the manual. I found them only by rummaging around in the electical section.
Consider buying two extra brass ferrules for the throttle cables, as it is likely you'll lose at least one. I did, and after a 30-min. search went to the HD dealer for more. After returning, I found the lost ferrule within 30 sec. in a location searched several times before. Typical. As I said, Murphy was awake and attentive that night.
The Harbor Freight extra-long needle-nose pliars is a good suggestion, as with them you can install the cable to the throttle body with ease.
Before you start take the little E clip in the kit go to local hardware store match it up and buy about 10 of them you are going to lose at least 2 before you get the clip on the cruise cable. Remember patience because that little clip is a bitch to seat on the cable end.
Install complete. Went pretty smooth with the exception of re-installing the ignition switch. Removed it while in fork lock position and then had to move it to remove the lower switch housing. What a PITA to re-install... used all my resources then had another beer to cool down....wallah! the switch went in and all is well. :-)
Thanks for all who posted in reply... I considered all the suggestions.
07, 2006, 2007, control, cruise, electra, glide, hd, instal, install, installation, installing, standard, street, streetglide
