Cleaning off the rear end
RE: Cleaning off the rear end
Its a complete kit...everything you need to eliminate the barexcept paint is in the kit.
The kit comes in two styles. One with the cutouts for a tour pack, and one without the cutouts which actually looks better.
Also, the picture I took was a peliminary test fit. They actually fit tighter around the fender once you adjust them.
For the record, I painted the fillers with vivid black right out of a Harley spray can. Then clear coated...again with a Harley rattle can. Think it came out ok...cost 40 bucks.
Hopes this helps...
lp
Hopes this helps...
lp
Sorry harleyhoots, I'm not tracking...
If you are asking if you can still use the HD detach stuff with the kit, then yes you can. There is no interference.
If you are asking if its a tighter fit than whats pictured, then yes itsa littletighter on both sides than what is in the picture. (not a big gap on both sides).
Furthermore, it covers all the frame stuff from the back to the front going under the seat...
I'll try to get some better pictures...
Just gotta find that dig-cam.
lp
lp
ORIGINAL: harleyhoots
lp, I have my detach mount for my tourpack by the back shocks and in the back like yours. Will this kit tight enough up in front. This is a nice kit.
