Whole Lot of Shakin' Going On
While patiently waiting at a red light, two other earlier model Ultra Classics pulled up beside me. After acknowledging one another, one rider commented on how much my mirrors vibrated.
Well, I thought the vibrations were pretty normal but did notice their's really weren’t moving at all.
My question…how much vibration is “normal” and when is it excessive? I do experience vibration to the point the mirrors are useless at idle and still quite blurry during most all cruising speeds.
I have an ‘08 UC with just 700 miles on it…all stock. I’ve read several posts about motor mounts and to check them. I’m expecting my service manual next week so I’ll wait for it before I begin taking things apart.
Your comments/suggestions will be appreciated.
RE: Whole Lot of Shakin' Going On
ORIGINAL: Pine Tree
This may not be your issue but it is very possible, worth checking.
Joe.
My 08 vibrates a lot more than the 04 did. I don't think that you have to worry about replacing the motor mount already on an 08 unless it was defective. You could try the Buell motor mount and see if that helps. Here is the LINK that talks about using the Buell mount as opposed to the HD one. Also gives the part number.
ORIGINAL: dawg
...I don't think that you have to worry about replacing the motor mount already on an 08 unless it was defective...
I did look at mine and it seems to be compressed and slightly deformed on one side. Not knowing what the torque value is, I'm not sure if that's "normal" or not.
I'll let the dealer take a look at it sometime in the near future...
ORIGINAL: KustomBaggers.com
Pull your outer fairing off ...This may not be your issue but it is very possible, worth checking.
Joe.
Joe.
Just had two of my fairing brackets replaced yesterday: https://www.hdforums.com/m_2737613/m...tm.htm#2737613
Primo
Primo
internet troll
06-09-2019 09:33 PM
