Fork oil amount
I'm putting progressive lowering springs on my front end soon (1") and was wondering if I should use the same amount of fork oil, or if I use less due to less travel? Tried a search, but no luck. Any help? Thanks
ORIGINAL: cwilks
You use the normal amount which I think is like 11.5 ounces
If you buy an H-D lowering kit it comes with the instructions.
for a 02-later roadking....for example....initial fill of 11.1 ounces and then take a depth measurement to the fluid with the forks collapsed and the spring out....adjust level to the correct measurement.
11.1 oz. is the correct amount according to the 2005 regular servicemanual for roadkings...so i does appear that the OE amount would be correct even with the lowering kit....
hope this helps
hope this helps
