Help Installing Fork Lowering Springs
Old May 4, 2006 | 03:23 PM
kaduku's Avatar
kaduku
Default Help Installing Fork Lowering Springs
I am preparing the arrival of my fork lowering springs. Don't know if they will include instructions.
Anyone with advice or instructions on this next project of mine.
Old May 4, 2006 | 07:50 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Help Installing Fork Lowering Springs
Instructions are in there....
You will need a few special tools.... Long Hex Driver (Size is dependent on year)
Slide collar for the Oil Seal (This can be made)...
Little bit of Fork Oil....
Fork Cap Nut Socket... Much better than a Crecent Wrench....
Torx Bit to loosen Triple Tree clamps...
All the tools are listed in the manual, as well as specs.....
Follow the Manual and instructions and you will do fine...
Old May 4, 2006 | 08:18 PM
kaduku's Avatar
kaduku
I didn't realize the triple trees clamps had to be loosened also. The only concern I have is that I don't have the manual.
Old May 5, 2006 | 12:50 AM
Shovelhead Bob
I would suggest that you either borrow one, or refrain from doing this task....
JMPO...
AUTOT3K
Dec 26, 2015 12:56 PM
Ncdyna925
Apr 9, 2013 01:18 AM
Reaper22
Oct 7, 2012 05:22 PM
WildBillAce2
May 20, 2009 12:49 AM
harleykris
Jan 30, 2008 10:08 AM
