Your progressive install instruction specifies how to measure the amount of fork oil after the spring install. I've had approximately 140mm of "empty" space left after installing standard progressive springs which equated to ~710mm of oil in each fork leg.
There is some common sense to this install in that your preload spacer shouldn't protrude "too much" above the top of the fork leg. It looks to me that you've overfilled the fork leg and as a result blown your fork seal.
