Installing the front fork lowering kits?
Old Oct 7, 2012 | 10:09 AM
Reaper22's Avatar
Reaper22
Default Installing the front fork lowering kits?
Is it difficult installing the Harley front fork 1" lowering kits? And do I need to just add oil? cuz didn't really want or need to take completly apart only got 600 miles on bike. I was told did not have to take completly apart to install these, just gettn other opinions..
Old Oct 7, 2012 | 02:59 PM
Reaper22's Avatar
Reaper22
Is there anyone who has done this before??
Old Oct 7, 2012 | 03:13 PM
mrfuji's Avatar
mrfuji
Default installing the front fork lowering kits
hi.the harley kit.is..the damper is shorter .1.or.2 inches .harley have 2 numbers. the damper are in lower leg. hold by allen bolts. under front axel.you have to remove whatever is on front off your bike .whell fender light fairing .to have acces to your fork tube cap..screw . may be able to pull the tube with out pulling the top tree . this is a projet . mrfuji
Old Oct 7, 2012 | 03:39 PM
HogglyWoggly's Avatar
HogglyWoggly
I have not used the Harley kit but instead installed progressive monotubes to get front end 1" lower. I highly recommend the monotubes based on my experience. Much firmer suspension. My bike was also almost new when I did this. The monotubes also do not use oil for damping.
I have never been into front suspension before doing this but with the service manual and the forum here was a fairly straightforward job.
Just my 2 cents; your mileage may vary.
HTH
Hoggly
Old Oct 7, 2012 | 04:47 PM
aviscomi's Avatar
aviscomi
HTH
Hoggly
+1 on installing the MonoTubes. Its about a 2-3 hour install and well worth it.
Old Oct 7, 2012 | 04:53 PM
Pioneer74's Avatar
Pioneer74
Question about the monotubes.
If you install the monotubes, would that also be a good time to install the chrome forks and cowbells? Also, by using the monotubes, do you totally eliminate the oil?
Old Oct 7, 2012 | 05:22 PM
aviscomi's Avatar
aviscomi
That's exactly what I did. Also, there is a very small amount of oil used with the Monotubes and its only used for lubrication purposes.
MHRider
Mar 3, 2013 06:43 AM
darius28x
Jul 17, 2009 01:53 PM
1sportytrike
Feb 16, 2007 12:20 PM
wideglidebob
Dec 7, 2006 10:54 AM
kaduku
May 5, 2006 12:50 AM
